Question Monitor audio silver sfx wall mount
PhilPR
Hi all, recently changed my old amp to a denon x2600h, and as a result decided to add some extra rear speakers for 7.1.
I have got some older MA Silver sfx speakers which don't have wall mount brackets on. (not to be confused with fx speakers)
Anyone have any idea how these should be mounted? Or where I can buy the brackets?
Any help appreciated as my Google-fu has completely failed to come up with any answers.
pops107
Have you asked monitor audio they are very helpful give them an email
pops107
Wonder if the brackets of the bronze FX would fit ?? Looks like you have the hols for them
PhilPR
I am in contact with MA, the chap I am dealing with is struggling as the speakers date before his computer system begins 😁 Even the serial numbers don't appear in his system.
I think he is still down in the basement searching through files!
I was thinking of the current bronze fittings, I will ask him when he comes back to me next.
pops107
Mite be a case of only using one of the original holes and making another looking at them looks like there pilot holes for screws or are they threaded ones
How about these
Amazon product
PhilPR
The sfx speakers have indents as pilot holes, will measure the gap later as it would be interesting to compare to the gap between bronze fittings holes.
PhilPR
Those fittings look OK, but may be too close to the speaker back. It is not quite flush, the cable poles protrude a little. I would rather have the fitting on the speaker rather than the wall as the weight can be split over 2 screws that way.
pops107
You could pop a couple of washers behind them them to lift them away from the speaker a bit and can add or remove as many as you need
pops107
Hope you get sorted
Just looking at getting some silver fx my self
PhilPR
I love their look, trying to resist adding a second subwoofer on a wireless link but then that's it. I keep telling myself that, darent tell the wife..
pops107
No what you mean I have a xxls400 at the moment and love it but would love a mono don't no how I would seek that in the room
pops107
Where on the wall are you fitting your SFX
That is my issue
pops107
On the back wall
Mine are going to go on the sides but they will only be about foot and 1/2 from back wall and above door frame
PhilPR
I have side speakers at that position, but not so high.
Really pleased with sound since changing amp, great effects coming through. Not sure how much better it will be with 2 extra rear surrounds added, but couldn't resist now the new amp is 7.2 capable.
pops107
Yes mine is 7.2 but can't do backs not got the space have played with front height
PhilPR
Did you feel any benefit? I am dubious about Atmos, rather get a better sense of surround laterally. But I haven't tried to be honest, just a gut feeling.
pops107
Mine doe snot do Atmos only pro logic 2z
But to be honest don't think I got what I was expecting
LG C1 OLED TV Best Picture Settings for SDR, HDR and Dolby Vision
