monitor audio silver av1
Discussion in 'Home Cinema Speakers' started by jason t, Nov 23, 2001.
  1. jason t
    jason t
    Mar 4, 2001
    1,707
    48
    kent
    +38
    hi has any body got the monitor audio silver av1 package if so can you please tell me if its any good ?
    are the rears better than the mission 77ds ?
    if i bought the 8i fronts and the 10i silver would the mission 77ds be ok for my rears?
    what sub would you recommend if i just bought the three fronts?
    thanks
    jason:confused:
  2. John_bones
    John_bones
    I've got the package which includes the 3i's for rears and am very impressed. Only trouble is I can't compare to the Missions. The front 3 certainly have bags of bass when needed although I've got a Rel Q50 to do the lower down honours. Go for it!!!
    System:-
    Pioneer VSX-859RDS
    Pioneer M-10X
    Samsung DVD709 (upgrading to Pioneer 747 if and when)
    Marantz CD63KI MK2
    + other bits and bobs
    Using QED Silver Anniversary Bi-wire + various QED interconnects
