Monitor Audio Silver 5i's
Discussion in 'Home Cinema Speakers' started by TobyJ, Nov 8, 2001.
  1. TobyJ
    TobyJ
    Anyone got any views on these, based on first hand experience or otherwise, and what would the logical competitors be?
    (I'm looking for front speakers for the hi fi separates, which will then form part of a Home Cinema set up).
  2. Alan_W
    Alan_W
    Sep 20, 2000
    1,393
    S Wales
    +188
    I have auditioned the Silver 5's against Mission 773's which thought I wanted. The MA's were so much better. Mad the Missions look and sound cheap.
    Only problem for me is placement. They are rear ported and need to be placed further from the wall than my wife will allow.:mad:
    They sound really great though, and I am working on getting the Silver5's, Silver 10 center and probably the Mission 77ds as rears cos they're great.
    Also check out the Kef Q range. Possibly bargains to be had at present as they have just been replaced.
    Alan
    PS Have you listened to the Silver 8's.....If I can just move that wall:rolleyes:
