Monitor Audio S8 or GR10?
Discussion in 'Home Cinema Speakers' started by phillfyspoon, May 12, 2005.
  1. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    I have MA S1 fronts right now want an upgrade for hifi use and want to keep to MA coz i like there sound but which to go for Monitor Audio S8 or GR10?
    bookshelf vs floorstander
    I guess the best thing to do is get a demo butcant find anyone with both.
    anyone else heard both?
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    Definitely the GR10s, much better than any of the Silver series which is now discontinued anyway.
  3. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    discontinued and very cheap.
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    Just because you can get it very cheap doesn't mean it's going to be any better for you system. Decide on a budget for speakers and then listen to all that fall within that budget ignoring any price differences, that is how to demo speakers. If you can't afford £800 for the GR10s then they are not in the running, if you can then listen to them and the S8s and make your own mind up.
  5. recruit
    recruit
    Agree with Crustyloafer the GR10's are pretty special compared to the S8's and definitly worth the money.
  6. yant
    yant
    Dec 8, 2002
    264
    28
    +32
