Monitor Audio S1 Silver good buy?
Discussion in 'Home Cinema Speakers' started by 5ergo, Mar 8, 2005.
  1. 5ergo
    5ergo
    Mar 7, 2005
    91
    9
    Hello. :hiya:
    Im thinking of buying those for a long time.Id have them on Onkyo receiver with crossover set to 60Hz.I already have a (weak) sub but sooner or later ill get one of the SVS cylinders.
    So is it ok to have crossover set that low with these speakers?
    So if you have experience with those id be glad to hear it from you.
    I can get them for approx 375Euros.Good price?
    I wanna know if they are really that good because there are some Tanoys very cheap.
    Is anything wrong if i connect S1s (which use 80W RMS) to receiver with 115W per channel?
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    I have the s1's for my fronts. and I must say i love them. I demoed them against speakers costing £995, £925, £900 PMC, dynaudio, audiovector. they all sounded the same really but the s1's stood out by miles. it has a very fast, detailed punchy sound. they need alot of running in due to metal drivers. 115w is fine I run them with 110w. you do more damage uner powering speakers. there were 3 members of my family in the demo room and they all went WOW to the s1 "how much are they alot more i bet" no i said 3 times cheaper. but the saving to good use was almost decided on the dynaudios which were £900 but I remembered someone else had the same experiance.
  3. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,091
    notts.
    +64
    Having owned the s1s i can say they are a very nice sounding speaker just give them a bit of room to breathe though or they can sound boomy.
    Cheers Gonzo. :)
  4. GW43
    GW43
    Feb 27, 2005
    1,631
    63
    Out of my mind on dope and speed
    +162
    MA Silver S1 are excellent.
    Put them on high stands (600mm), keep them at least a 30-45cm from rear walls and they will fly!
  5. 5ergo
    5ergo
    Mar 7, 2005
    91
    9
    Thank you all for the info!
    Ill sure wait for the new RS series and than ill buy one of them (S or RS).
    Im glad to hear they are not that much better than Dynaudio (audience right?).Cause i was thinking about Dynaudio audience 52SE but they are more than twice as much as MA.Dynaudio should have better tweeters but who cares.
    I think if S1 can hit 45Hz well than i could have crossover set even lower than 60Hz.But i cant find a receiver that would have an option below 60Hz (at least not in 500USD range).
  6. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    I dont know how clean that 45hz is. i would of thought it would produce clean output in the mid 50hz range then get lower down to 45hz so a crossover at 60hz would be about right.
  7. OneDesi
    OneDesi
    Mar 10, 2005
    8,513
    Black Country
    +255
    I used to have the S1's and thought they were great - precise, detailed and well balanced. I then upgraded to the Silver S6 floorstanders (which I recently compared to some Quad 12L - the S6 were streets ahead IMHO).
    If you want to buy the current range then Sevenoaks are clearing them out to make way for the new range so a bargain could be had soon!
  8. howesey
    howesey
    Yeah, Sevenoaks Wolverhampton have some stonkin' deals on the Silvers.
  9. Drd
    Drd
    Jan 22, 2005
    1,904
    Approaching the doghouse at great speed
    +301
    I would agree entirely,I was very disappointed when I auditioned the Quads and eventually bought S6 fronts,S2 rears and an SLCR centre.I'd recommend them to anyone,but they would be foolish to take my advice!As ever,let your ears decide and make your own mind up,then you know you'll be happy.
