monitor audio s1 plus matching centre
Discussion in 'Home Cinema Speakers' started by Andywilliams, Jan 7, 2003.
  1. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    hi all
    has anyone got or heard these speakers quite intrested.?
    cheers gonzo
  2. Godfather
    Godfather
    Feb 12, 2001
    2,223
    63
    Edinburgh
    +224
    I've got the Monitor Audio Silver 1 as my mains and a matching Silver centre. They sound excellent and more neutral than the equivalent B&W 600s which I also tried.
  3. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    hi godfather
    can you tell me if they are okay to position close to a wall.Mine would have to go either side my tv in a corner.At the moment ive got mission m71is and m7c2 centre with the bungs fitted to keep the bass tight.I would be keeping my m7ds for rear surround duties. Thanks gonzo.:)
  4. Godfather
    Godfather
    Feb 12, 2001
    2,223
    63
    Edinburgh
    +224
    My room is relatively narrow (9' wide) and I've a big widescreen RPTV so my main speakers are probably a bit too close to the side walls (about 30cm). The back of the speakers are about 50cm from the front wall. Sounds fine to me but I've got a feeling they're be even better if placed further away from the side walls.
