Monitor Audio RSW12 Problem
baronm
Hi All,
I'm having an issue with my Monitor Audio RSW12.
Most of the time it works perfectly, but occasionally, and seemingly more frequently, the audio is "sticking on" i.e. the film will move on to another scene but the sub will still be blasting out bass permanently (at the same frequency and high volume!), and can only be rectified by powering the sub on and off again.
The issue is across multiple sources (have had it on Blu-Ray and on HTPC). On Friday night for example, it had serious issues with the Blu-Ray of Big Trouble in Little China when it did it 4 times in the space of less than 10 minutes (from about 30 minutes into the film), and after the 4th I just left the sub turned off at the wall. We had watched The Warriors on Blu-Ray immediately before and didn't have a single issue, and I watched Jack Ryan: Shadow Recruit the following morning (film with lots of bass!) and had no issues at all.
Other items in my setup are listed in my sig.
Anybody had this problem or have any thoughts on what the cause (and solution!) is?
baronm
Nobody?
