Monitor Audio Radius R90AV or MS Prem Plus
Discussion in 'Home Cinema Speakers' started by jonandjen, Sep 15, 2005.
  1. jonandjen
    jonandjen
    Feb 9, 2005
    305
    28
    +28
    Thinking of going for one of these speaker packages. Appreciate the MA are twice the price (but they do look good and would pass the wife test!!) of the MS, but are they twice the performance / sound quality etc??
    Appreciate any views from owners of these speakers.
    Regards,
    jonandjen :thumbsup:
  2. skive
    skive
    Apr 30, 2004
    67
    Belfast
    Although this was a while ago I went for the MS over the Radius cos' of the price difference. I'm very happy with the MA premier and they sound great, the small speakers disappearing into the room when you are watching movies or listening to music. They don't look to bad either.
    Saying that - the Radius do look better (something that has become strangely more important to me!) but whether the sound is worth the extra cash will require a listen.
    skive
  3. jonandjen
    jonandjen
    Feb 9, 2005
    305
    28
    +28
    skive,
    Thanks for your views. Yes I agree. The MS certainly look good, but the MA are a tad better. Both have good reviews and general feedback, so a difficult choice to make. Will hold out for a few more comments, and will ultimately try and listen to both before taking the plunge.
    jonandjen
