Monitor audio plc350
Discussion in 'What Speakers Should I Buy?' started by freemanroad1986, Aug 16, 2013.
  1. freemanroad1986
    freemanroad1986
    Feb 12, 2013
    69
    11
    England halifax West Yorkshire
    Hi there I am new to all this but I have a monitor audio plc350 centre speaker what is the best way to run it.
    I am using a pioneer lx82 is that good enuff and what a processor do? Do I need to buy 1 and wire it to my amp and run it on that??
  2. Sutch
    Sutch
    Mar 16, 2003
    115
    Warrington
    +3
    Hi there, your amp should be sufficient but additionally any upgrade in your amp will really show the potential of your centre speaker. The best option imo is to have a 4 cable run and join to make 2 at your amp end and obviously output from your centre signal outputs on your amp into your plc350 using all 4 inputs. Interested in which cable you are using the rest of your speaker set up?
