Monitor Audio or B&W
Discussion in 'Home Cinema Speakers' started by unclej, Dec 6, 2003.
  1. unclej
    unclej
    Hi ,
    Im looking for a home theatre system, its between Monitor Audio Silver Series or B&W 600/601/602 series.
    Which one is better..
    Thanks.......
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,523
    3
    Aldershot, Hampshire
    +286
    I've owned B&W 602 series 3 speakers in the past and was very happy with their performance. They coped with everything I threw at them as well as looking gorgeous in sorrento finnish.They need a good amp to drive them though but I'm sure they'll not disapoint when you audition them. I have never listened to the Monitor Audio's so can't really comment on them although they seem to be highly rated on these forums.
    The best thing to do is go and have a listen to both makes as well as a few more (like Kef, Mission for example) at a local dealers preferably with music and dvd's that your familiar with. Try and get a similar sounding set up (amp and source wise) so you'll get to hear them under similar operating conditions as your home set up. Have a listen to as many makes as you can and find the ones that sound best to your ear for the money. Speaker choice is very subjective - what sounds good to me may not be the same for you and vice versa. The make of components you wish to use with them will also affect your choice as some bits of kit may sound better driving speakers you have chosen (to your ear) over others.
    happy hunting:D
  3. Ridcully
    Ridcully
    Feb 16, 2002
    356
    28
    +35
    As mentioned above the best thing to do is get a demo.
    I have
    F : 603 S3
    C : CC6 S2
    R : 601 S2
    SW : 675
    and think it sounds great but until you compare against another set you never really know.
  4. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    I'd say audition both but it's worth bearing in mind that Monitor Audio offer bipole/dipole rear speakers which may be an advantage if you require a more diffuse sound from the rear.
    Matt.
  5. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    B&W have the DS6 S3.
    MuFu.
  6. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Of course - I'd forgotten about those - my mistake - they are £500 mind!
    Just checked - they offer dipole or monopole and the Monitor Audio's offer dipole or bipole. Take your choice and pay your money!
    Matt.
  7. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    Tis true, not to mention rather ugly. :D
    MuFu.
  8. unclej
    unclej
    Thanks Guys....
    Decided to narrow my search to B&W 601 S3 for the 2 front and
    600's for the rear, center will be LCR60 S3.
    I listened to Monitor Audio's Silver 4i, they were pretty good , but to my ears they sounded alittle boxy. I think the B&W had better sound stage...What do you guys think....
  9. shawkins002
    shawkins002
    Dec 12, 2002
    237
    Epsom, Surrey
    I have this set up - very pleased. I'm currently doing without a sub because my walls are seemingly made of paper, but they go down low enough to annoy the neighbours still.
    You should be chuffed mate. Hope they work out for you.
  10. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Personally, I bought MA's after a demo of all of the brands that sevenoaks supply within this price range.
    But everyones ears are different.
    By the way, the silver 4i is from the old range I believe. If so, try and audition the new silver series, they're much nicer IMO.
  11. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    I used to have the same set up as shawkins002, except with a REL Q100E and the LCR600. Very nice... especially for a first system.
    Having said that, if I were to buy again I'd probably get Kef Qs (maybe 3 pairs of Q1s) as I have since auditioned them and prefer their sound to that of the B&Ws.
    MuFu.
