All the ones with the ++ symbols are non polarized electrolytics normally used to save costs and are smaller than their more expensive Polyester and polypropylene counterparts. The orange component in your pic look like 33 ohm resistors but you won't know for sure until you remove them and look at what's printed on them. They probably won't need replacing tho.
I have used the Mundorf Non polarized caps in a few speaker projects, they're not the best TBH, I found their sound to be poor especially if in series with the tweeter. If you can source them, ALCAP NP's are a lot better for sound quality, I believe Falcon Acoustics still have some stock, give them a call if you can't find the value you are looking for. I think they also do Solen caps.
If you have the space on the circuit board (and budget) to use polypropylene caps on the tweeter circuit then do it but be careful as large values can be physically LARGE and expensive so check sizes. You can find the tweeter capacitor by following the wire from the tweeter to the circuit board, the first caps you bump into are usually them (usually lower values 3.9uf - 10uf) If you are not sure post another picture of the complete circuit board.
The Solen or Ansar Supersound polypropylene caps would be my choice, superb sweet sound and not too expensive.
Solen Clarity Cap & Alcap capacitor, audio components & tolerances available for loudspeaker crossovers and networks.
www.falconacoustics.co.uk
