Monitor Audio GR Centre speaker
Minivan
I recently purchased a MA GR Centre speaker for my system. I'm just breaking it in, used less than 10hrs. It sounds good, but when i put my ear to it, it seems like one of the drivers is playing more than the other. The other one appears to be playing some of the lower frequencies, but is harder to detect.
Not sure if they're supposed to be playing the same frequency or not? If they are then it may be faulty. Anyone know about this? If they're supposed to play different frequencies then that's cool. I'm just being paranoid I think.
cheers,
John
GW43
I assume you mean the two main drivers are sounding different to each other, not just different to the tweeter that's in the middle of them? Forgive me if that's a stupid question, just covering all the bases:)
I would have thought that the two main drivers should have exactly the same output.
Knyght_byte
both mid/bass drivers should sound the same.........freqs, volume etc....
i'd get it checked out at a dealer......
oh, try it on another channel first on your amp just to make sure.....(its an LCR design so can be used on the front left or right as well as centre but use music as a movie track might not contain enough info)
Minivan
I was talking about the two main drivers, not the tweater. That would be funny though. :thumbsup:
Turns out that the two drivers are supposed to play different frequencies
Monitor Audio USA:
"It looks like a symmetrical array with matching midranges on either side of the tweeter, but is actually two mid/bass drivers tuned to different frequencies that work together to increase overall power-handling. This design is also said to minimize any of the lobing effects that can occur when you place identical midrange drivers on either side of a tweeter."
scoobysti
i had the exact thought myself so emailed monitor audio and got this response
Dear Dan,
Let me put your mind ar rest. This is exactly how the gold centre was configured when it was designed and one of the reasons it sounds so good. Although both drivers look identical, electronically via the crossover they are configured differently so that the left driver just does lower bass, and the right does upper bass and mid.
You will notice slightly more clarity if you remove the tweeter mesh from the tweeter. However this isnt advisable if you have small children!!
Please come back to me with any other queries.
Best Wishes
Alex Brady
UK Sales Manager
Knyght_byte
well blow me down with a feather....
i figured being LCR speakers they'd need to be balanced....oh well, me wrong on my favourite brand...how can i live it down :(
no one tell badger or crustyloafer under any circumstances!!!!
heh ;)
edit: wonder if my SLCR is the same.....have to have a listen when i get in now..lol
Dankeech
Thanks minivan!
Learn a new thing every day they say...
Well your post has taught me something and if anyone every asks the question of me I can answer without turning out to be utterly wrong =] :thumbsup:
Dan.
Knyght_byte
Dankeech said:
Thanks minivan!
Dan.
dont rub it in...lol
:D
Crustyloafer
scoobysti said:
Dear Dan,
Best Wishes
Alex Brady
UK Sales Manager
Alex Brady from Monitor Audio is a top man and knows what he is talking about. He is the MA rep for our store and he really knows his stuff. Top bloke.:thumbsup:
