Monitor Audio Cabling
Discussion in 'Cables & Switches' started by Scotty Boy, Oct 11, 2004.
  1. Scotty Boy
    Scotty Boy
    Nov 11, 2003
    1,076
    38
    +6
  2. bobbypunk
    bobbypunk
    it is alot easier to manipulate than it's peers it's a reasonable cable but is going head to head with QED silver anniversary as it is £5 per metre! I would only buy it over the QED if you need it to be more flexible.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,499
    Edinburgh
    +1,236
    We sell it at Sevenoaks Edinburgh, It is £5/m as mentioned above and I feel it offers all of the benefits of Silver anniversary without the coarse treble. It is also really easy to strip and flex around corners. If you are after some then give me a call at the shop.
    Chris.
  4. Scotty Boy
    Scotty Boy
    Nov 11, 2003
    1,076
    38
    +6
    How much does QED silver go for nowadays? Is this MA cabling as thick as the Silver anniversary?
    I might have to get some pretty soon, i'll give you a PM crusty when I do.
    So you would rate it higher than the QED SA?
  5. bobbypunk
    bobbypunk
    I would agree with the coarse treble but I would say it is subjective which one sounds better. I find the silver offers more detail in general and a much cleaner bass.
