Monitor Audio BX2 speaker stands: Atacama / Custom Design / Sound Style
andreim
Hello,
I'm having a pair of Monitor Audio BX2 speakers used with a Sonos ZP120 2x55W multimedia device. I am planning to buy some stands for these speakers and I need your advice. Until now, I've had spotted some models and I've read some reviews about them:
Atacama Aurora 6
Atacama Duo 6
Custom Design FS104
Sound Style Z2
The budget is about 300USD/200GBP. Also, consider that the external dimensions of BX2 are:
(H x W x D)
350 x 185 x 255 mm
13 3/4 x 7 5/6 x 10 1/16 inches
The room is quite small and it has about 3m x 5m. I've chose these type of speakers due to the front bass reflex (so I can put them close on the walls), good frequency response and perfect impedance match with my amp. Finally, I'm having a Sonorous PL2500 TV stand in black for my LED TV and other equipment. In future, probably I will use these speakers with a Marantz NR1603, but I haven't decided yet to this purchase.
Your advice would be kindly appreciated!
Thank you,
Andrei
push
I would add a vote for Apollo Olympus 6s... they are really solid and can be filled with bags of sand/shot easily to increase stability. They are approx £100. I recently bought some of these to match a pair of AVI ADM9s which are 200mm(w)x250mm(d).
In another room, I use some Atacama Nexus 6s, which I've had for nearly 10 years and they have served me very well.
Both are good but I prefer the single column design and stability of the Apollo's. Just my 2 pennies worth. :)
Richy1984
If you are anywhere near Cardiff, I have some Atacama Nexus 6i stands I'll be getting rid of in a couple weeks.
Nevaborn
I got mine with some atacama's look nice and sturdy. When i tested the bx2's tr stands were recommended. I managed to get a pair for only £20 off ebay. Was well pleased.
stevebrockelsby
Hey nice one, hope you enjoy the speakers anything from atacama and soundstyle would be fine!
l34052
I had bx2's on a set of atacama hms2 stands which are very solid weighing around 14kg each empty.
Have a look on amazon cause they were £179 a set if they have them instock still.
The top plates are actually abit wider than the bx2's but the sound was fantastic.
Similar threads
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
