Question Monitor Audio BRONZE FX surround - what front/centre/subwoofer and avr would you reccomend?
Discussion in 'Home Cinema Buying & Building' started by wakkaday, Jun 12, 2018.
  1. wakkaday
    wakkaday
    Jul 13, 2010
    32
    hi guys
    i have purchased
    Monitor Audio BRONZE FX surround speakers in white
    now i need 2 front speakers (wall mounted)
    what would you reccomend, mainly for tv/movies and occasional listening i guess...
    is the denon 2400 worth getting or holding back for the newer models? i heard the sony str-1080 is similar...
    thank you
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,385
    The Borders
    +3,433
    Not sure you need everything in BOLD :)
    AVR - which Features do you need or want to support? If the 'out going' models cover you then you can usually make a decent saving on those.
    AVR - Denon vs. Denon vs. Sony, other than Features there is no way to say one will suit you better than the other.
    Front LR Loudspeakers - On-wall suggests 'limited' range so you may have to also include a Sub in your system plans. Are you looking for White On-wall speakers to match the look of teh surrounds?
    Joe
