Monitor Audio BRFX for RS6+RSLCR
Discussion in 'Home Cinema Speakers' started by CaRaBeeN, Jun 15, 2009.
  1. CaRaBeeN
    CaRaBeeN
    Mar 17, 2008
    3
    +3
    To save some money I'm thinking of buying BRFX instead of RSFX.
    I already have RS6 for fronts now..I'll be buying RSLCR in couple of weeks plus I consider buying BRFX
    What do you think is it worth spending double for RSFX?
    I listen music in stereo mode , I don't like 5.1 music.So rear channels will be used only in movies..
    Thank you
  2. Madskilzz
    Madskilzz
    Mar 16, 2002
    348
    Harrow
    +73
    I have been using bronze rears with silver s6s and gold gs10s and I have never had the urge to upgrade. You'll be fine save your money. :smashin:
    Mark
  3. Andrew K
    Andrew K
    Oct 14, 2004
    3,392
    +608
    you'll be fine with the BR-FX
  4. Maharg
    Maharg
    Feb 2, 2007
    474
    +10
    My previous set-up had BRFX's matched with RS5's and an RSLCR. Seemed to work fine together...
  5. invisiblekid
    invisiblekid
    May 10, 2009
    4,765
    4
    +3,675
    I have the RSFX and they do sound fantastic. Not heard BR's so cannot tell you you MUST get the RSFX. What are the prices you have been quoted? If the RS's are a fair bit more then I don't think you'll miss them as i'm sure the BR's will sound just fine.
