soziblewuup
Established Member
I'm looking to upgrade my Monitor Audio BR2's.
First off, I should probably say I'm not looking to sidestep. It's only going to be worth it, for me, if I'm really going to notice quite a difference. At the same time I'm not looking to spend a fortune (surprise, surprise). Maximum £350ish/ maybe £400 at a real push, so will most likely be looking at the second hand market.
I'm looking for clarity and clear separation (I think). The reason for this is I think the BR2's sound a little coloured in the mids; things can sound a little muddy. I've always liked the highs on the BR2's, they're crispy without being too bright.
My Gear:
- Monitor Audio BR2
- Soundstyle Z2 Speaker Stands
- Pioneer A-676 amp (1991)
Power output: 70 watts per channel into 8Ω (stereo)
Frequency response: 1Hz to 150kHz
Total harmonic distortion: 0.007%
Damping factor: 70
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 76dB (MC), 94dB (MM), 110dB (line)
Output: 150mV (line)
- BK XXLS400 Sub.
The biggest downside of my set-up is that I have nothing that gives me the ability to EQ / cut the bottom end frequencies of my speakers. The lower frequencies of the BR2 tend to roll into one with the sub, and on occasion it can get a tad boomy.
Anyhow any suggestions / feedback for good speaker pairings with my setup / any other advice.
Much appreciated
edit: Maybe I should mention I listen to a whole range of genres. Classical, electronica, Chill-out etc. Not so much heavy electronic genres like Electro House, and no heavy rock.
My Gear:
- Monitor Audio BR2
Damping factor: 70
- BK XXLS400 Sub.
Much appreciated
