Question Monitor Audio Apex AW12
disco74
Hello Everyone
I am after some help/advice
I have just bought a Monitor audio Apex system.
With that comes the AW12 subwoofer. I used to have a BK XLS200 which worked fine.
I am having trouble with the AW12. I believe I have set it up correctly and I have set the power mode switch to auto but for some reason it doesnt turn itself automatically.
If I turn up the volume on my amp(Denon X2600h) really high, sometimes it does come on.
It also puts itself into stand by when I turn the amp down or if there is a long, quiet scene in a movie.
Could it be my amp is not powerful enough?
Is it safe to leave the subwoofers power mode switch in the always on position?
Many Thanks
Scottgough
HI
Yes it's perfectly safe to leave in the always on position. Regarding the auto on, what's the amp set the subwoofer level at? Sometimes the trigger signal can be particularly weak if the amp has set the level to very low, I had a similar problem with a Velodyne sub, the amp always set it to -12db, even if the subwoofer gain was turned right down, solved it by leaving it on all the time.
disco74
yes when I ran the audyssey setup the amp had set the sub to -12 for some reason but I noticed this straight away and changed it. It is currently at +5 but I am still having problems?
Scottgough
Not sure why if it's set to +5, should definitely be getting a strong enough signal.
disco74
I am right in thinking I only need to connect the sub to the amp via 1 RCA cable?
Scottgough
Yes that's right. When it is on, does it sound ok, sufficient volume? going from an amp set -12 to +5 is a big jump
disco74
yeah sounds good when it works. These Denon amps tend to default to -12 on the sub a lot of the time when first calibrated for some reason. If I can get the sub working properly I will turn it down.
disco74
Im going to try another RCA cable too just to rule it out
Gasp3621
If you get -12db then the gain knob was set too high, make smaller adjustments. Run the Audussey 3mic position which ever is fastest, then press calculate and re-check the level. If you would get it to around -8db it would be fine! Don´t touch the knobs afterwards though, you can tweak the level from menu to get more shaking. Typically 3-6db for products with Audussey. So from -8db to -5db example.
disco74
Would the crossover settings have any bearing on this? The A40 and 4x A10's are all currently set to 80hz
disco74
I had the gain set to the half way mark but I will run it again tonight and see
Gasp3621
No!
If a digital AV processor or AV receiver/amplifier is to be used, a single cable can be connected from the ‘sub out’ or LFE connection on the amplifier to the RCA input connection on the AW-12 labelled ‘R’.
Phase 0.
Frequency knob to 120hz.
Power Mode On (when running Audussey so it won´t sleep)
Low Pass Filter OUT/LFE
disco74
OK will do. Thank you for your help Sir
gibbsy
On the Denon have you set the speaker size to small?
disco74
Yes all are set to small with an 80hz crossover
disco74
So I ran Audussey a few times adjusting the subs volume as I went. I got it up to -5db with the subs volume set to around 9 o'clock. Now the sub turns on when it should and is staying on for now.
Thanks for your help on this guys(especially Gasp3621. I owe you a cold one).
Is -5db/9 o'clock ok or should I be aiming for -8
Gasp3621
It`s fine! If you want more oomph just lower the figure (-5db -> -2db or bit lower) without touching the knobs. Easy to do from menu while you drink cold ale on couch! Enjoy! 😎
disco74
Just a quick update. I recently bought a Denon x3700 receiver. This has a 12v trigger for the subwoofer so I thought I would get a trigger cable and give that a try but unfortunately this creates a low hum across all of my speakers! When I unplug the trigger cable the hum stops? Anybody know of a solution for this please.
