Monitor audio apex a10
Boremc
Hi! I have gotten a cheap opportunity of the apex a10 audio monitor speakers (220 euros) ...
They seem beautiful to me and my wife is one of the few speakers that says "how beautiful" ....
What do you think for a room of 30 square meters?
I have read in forums that they are more than what they appear
With what center could they be combined? if i don't have the apex a40 center ...
Thank you so much!
Gasp3621
Hello.
See the post below @martin 39 has Apex A10 with MA Silver Centre. You can get the latest range now below 300£ as new model is coming, see the 2nd link and scroll until you see Silver C150.
If you sit ~3meters away then the A10 should work fine still when partnered with a good subwoofer. I am also assuming you aren´t after some real cineme volume levels so more of moderate loud lounge usage. :)
Gasp3621
Forget the 2nd link it doesn´t have gloss black C150 which you want with A10s.
Richer Sounds has one still, but not for long!
Specs here:
Boremc
Specs here:
im from spain...
Boremc
All the people consider that two aapex A10 IS enought like front speakers in a room 35 metres?
Gasp3621
If you don´t sit too far away from them and not after real cinema levels then you should be fine with A10s when you have subwoofer to support them. 220€ is very cheap price for them used, i would happily buy them right away! The stands are very expensive for those, but hopefully you will have wide and high enough av-cabinet to put them or wall mount.
Gasp3621
And what IS the best center for this speakers? Not a40... Vert very expensive
This one would be ideal and similar quality wise. -15% discount as new range coming soon:
Or if you find used Monitor Audio Silver 5G Centre locally:
And of course if the guy has another pair of A10 for sale then buy those and use one as center channel. Perfect match.
Boremc
ok thank u!
What the best configuration? the apex or its better Dali opticon lcr + dali opticon vocal?
Gasp3621
ok thank u!
There is no best for everyone, you need to listen both and then choose which sound you like more. Both very good options. Quality subwoofer is needed with both.
