Mondeo - Replacement Speakers
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by mundanojim, Dec 19, 2006.
  1. mundanojim
    mundanojim
    Please help - opinions needed! I am taking delivery of a new(ish) Mondeo ST220 estate in the next few days and having had a TDCi 130 GhiaX for two years, I want better speakers. The new car has the factory-fitted DVD sat nav system. I have looked at the Pioneer website and they do the direct-fit TS-H683, but are there better speakers available? Budget - within reason - is not a problem. I think that the audio sound in the Mondeo is okay but would definitely benefit from upgraded speakers.
    Many thanks
    Jim
  2. Dave
    Dave
    Jul 3, 2005
    11,496
    163
    +3,401
    Sony did a range of replacement speakers at Halfords. Not bad at all IMO.
  3. Ayub
    Ayub
    Oct 15, 2003
    6,657
    Bradford
    +612
    Jim, its all about what you like. Most speakers will be able to drop right into the slots with a little tweaking.
    Go to a shop which retails soeakers. USE YOUR OWN TEST cd and listen to it with the bass treb on zero and make up your own mind.
  4. fasterfords
    fasterfords
    Dec 24, 2006
    96
    +3
