Momitsu V880 - Panasonic TH-AE500 Custom DVI Settings!
Discussion in 'Blu-ray & DVD Players & Recorders' started by Drew2, Aug 29, 2005.
  1. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    Well here's a good list of custom settings for you to try. I would give each one a go and see which is best for your setup.
    My personal favorite just now is the DVI/HDCP derived. :thumbsup:
    On another thread I confirmed that I have managed to update the player to firmware 1.1.13 so I can't confirm if the following works on 1.1.12 - when selecting the 750p @ 50Hz or 750p @ 60Hz presets EDID 1 displays "750p" change too EDID 2 and it displays "WIDE 720". Both channels are working!!
    Could someone confirm that this is the case on their firmware version.
    Please note that you will need to select another input on your projectors remote then return to DVI to resync picture - so don't panic when you see big vertical bands before doing this!! :eek:
    Note: PC = Pixel Clock
    Original 1:1 setting @ 60Hz - PC ?
    Horizontal Freq. 44760
    Vertical Freq. 6000
    Video Width. 1280
    Video Hight. 720
    HSyncTotal. 1664
    PreHSync. 0056
    HSyncActive. 0136
    PostHSync. 0192
    VSyncTotal. 0746
    PreVSync. 0001
    VSyncActive. 0003
    PostVSync. 0022
    HSyncPolarity. 0000
    VSyncPolarity. 0000
    D-TV @60Hz - PC 74.250
    Horizontal Freq. 45055
    Vertical Freq. 6007
    Video Width. 1280
    Video Hight. 720
    HSyncTotal. 1648
    PreHSync. 0096
    HSyncActive. 0048
    PostHSync. 0224
    VSyncTotal. 0750
    PreVSync. 0005
    VSyncActive. 0005
    PostVSync. 0020
    HSyncPolarity. 0000
    VSyncPolarity. 0000
    LCD Display @60Hz - PC 74.531
    Horizontal Freq. 45007
    Vertical Freq. 6000
    Video Width. 1280
    Video Hight. 720
    HSyncTotal. 1656
    PreHSync. 0088
    HSyncActive. 0056
    PostHSync. 0232
    VSyncTotal. 0750
    PreVSync. 0004
    VSyncActive. 0006
    PostVSync. 0020
    HSyncPolarity. 0000
    VSyncPolarity. 0000
    DVI/HDCP Derived @60Hz - PC 74.156
    Horizontal Freq. 44998
    Vertical Freq. 5999
    Video Width. 1280
    Video Hight. 720
    HSyncTotal. 1648
    PreHSync. 0128
    HSyncActive. 0040
    PostHSync. 0200
    VSyncTotal. 0750
    PreVSync. 0005
    VSyncActive. 0005
    PostVSync. 0020
    HSyncPolarity. 0000
    VSyncPolarity. 0000
    EIA/CEA-861B @60Hz - PC 74.250
    Vertical Freq. 6007
    Video Width. 1280
    Video Hight. 720
    HSyncTotal. 1648
    PreHSync. 0112
    HSyncActive. 0048
    PostHSync. 0208
    VSyncTotal. 0750
    PreVSync. 0005
    VSyncActive. 0005
    PostVSync. 0020
    HSyncPolarity. 0000
    VSyncPolarity. 0000
    750p/50 @50Hz (EDID 1 ONLY) - PC 74.250
    Horizontal Freq. 37424
    Vertical Freq. 4989
    Video Width. 1280
    Video Hight. 720
    HSyncTotal. 1984
    PreHSync. 0440
    HSyncActive. 0048
    PostHSync. 0216
    VSyncTotal. 0750
    PreVSync. 0005
    VSyncActive. 0005
    PostVSync. 0020
    HSyncPolarity. 0000
    VSyncPolarity. 0000
    Unknown 1 @60Hz - PC 74.250
    Horizontal Freq. 44621
    Vertical Freq. 59814
    Video Width. 1280
    Video Hight. 720
    HSyncTotal. 1664
    PreHSync. 0056
    HSyncActive. 0136
    PostHSync. 0192
    VSyncTotal. 0746
    PreVSync. 0001
    VSyncActive. 0003
    PostVSync. 0022
    HSyncPolarity. 0000
    VSyncPolarity. 0000
    Unknown 2 @60Hz - PC 74.250
    Horizontal Freq. 45106
    Vertical Freq. 6014
    Video Width. 1280
    Video Hight. 720
    HSyncTotal. 1664
    PreHSync. 0056
    HSyncActive. 0136
    PostHSync. 0192
    VSyncTotal. 0746
    PreVSync. 0001
    VSyncActive. 0003
    PostVSync. 0022
    HSyncPolarity. 0000
    VSyncPolarity. 0000
    Good luck and have some fun messing about!!
    Please leave comments about how you got on.... :smashin:
  2. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    I noticed Panasonic has a table at the back of the instruction manual displaying values for each display output.
    They listed the following one for WIDE720:
    Horizontal 45.106 Vertical 60.141 Pixel Clock 76.500
    I gave it a try, the rest of the configuration matches the one for the LCD setting;
    LCD Display @60Hz - PC 74.531 changed to 74.700
    Horizontal Freq. 45007 changed to 45109
    Vertical Freq. 6000 changed to 6014
    Video Width. 1280
    Video Hight. 720
    HSyncTotal. 1656
    PreHSync. 0088
    HSyncActive. 0056
    PostHSync. 0232
    VSyncTotal. 0750
    PreVSync. 0004
    VSyncActive. 0006
    PostVSync. 0020
    HSyncPolarity. 0000
    VSyncPolarity. 0000
    The only things to note that the Horizontal frequency was slightly increased and the pixel clock is no where near what they printed. I then increased the clock upto the stated 76.500 and could not obtain any picture regardless of frequency range - possible printing error as other figures quoted matched the displays output.
    I will use this setup for next few days seeing how it is the closest to Panasonic recommended setting.
    If you jump between EDID 1 & 2 you can see how the setting uses the full LCD panel and how 750p is compressing the signal.
  3. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    The settings for this projector also work ( same LCD panel ) so would guess that you could also use on the Epson TW10 or 20?
    You can find the Z2 settings on the Momitsu site...... :smashin:
  4. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
