Momentary flicker between scenes
Discussion in 'Projectors, Screens & Video Processors' started by MikeFish, Nov 21, 2004.
  1. MikeFish
    MikeFish
    When watching DVDs on my plasma I get a momentary flicker between scenes. I tried plugging the DVD straight into the plasma (bypassing the amp) and using different cables but it made no difference.
    It then occured to me to switch off the progressive output. Switching into interlaced mode and the problem goes away.
    Anybody have any idea what the problem could be?
  2. PhilB1234
    PhilB1234
    I sometimes notice it and wonder whether it is poor editing/mastering, where the frame repition sequences aren't matched between different scenes. This may mean the de-interlacer has to restart it's frame count.... Although, the de-interlacer in your display doesn't appear troubled when fed an interlaced version.....
    Anyone else got any ideas?
  3. MikeFish
    MikeFish
    You noticed it too? If it is poor mastering/edititng at least I'll know it not a fault with my gear/ste-up.
    When I get the chance i will run a component cable to my projector & see if the same happens (using s-video at the moment. At least then I will know if it's the DVD player or the plasma.
