Mods for PB6100
Discussion in 'Projectors, Screens & Video Processors' started by Deepsnoozer, Jun 30, 2005.
  1. Deepsnoozer
    Deepsnoozer
    Mods for the PB6100
    I wish to improve my PB6100, i'm projecting a kind of small image, only arround 65" i wish to go up to the 75" but i'm already max zoomed, is there any mod i can do to change this?
    Also how can i improve the whites (yes the whites are not as white as they supose to be, and how can i improve the blacks?)
    Best Reards
    Dan
  2. cyberheater
    cyberheater
    Apr 3, 2003
    3,225
    Scotland
    +179
    What source or you using for your projector. My BP6100 whites are a very bright white.
  3. Deepsnoozer
    Deepsnoozer
    i'm using RGB
    btw is there any kind of lent i can buy so i can have a better zoom?
  4. cyberheater
    cyberheater
    Apr 3, 2003
    3,225
    Scotland
    +179
    Yes there is. You can use a wide angle lens that they use for camcorders which can give you a much shorter throw or a much bigger image for the distance.
    I'll see if I can dig up some info for you.
  5. Deepsnoozer
    Deepsnoozer
    hi
    Well, i got this guy i know , he's the owner of serveral Optic Centers (is that the right way to say it? where you buy your glasses and stuff?) and he can make me all lind of lens
  6. cyberheater
    cyberheater
    Apr 3, 2003
    3,225
    Scotland
    +179
