Modifying Gamecube RGB Scart for SNES
Discussion in 'General Video Gaming Chat' started by Bada Bing, Sep 25, 2004.
  1. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    I'm not sure how to do this, but I remember something about removing the capacitors. Anyone got a guide, or done it before?
    Cheers,
    Gareth
  2. supersonic87
    supersonic87
    Dec 31, 2003
    290
    Swansea, Wales
    As long as it's a PAL SNES then it should work without any mods.
  3. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    Are you sure? I heard something about the picture displaying perfectly for a few seconds, then becoming whited out... maybe just on certain models?
  4. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    Yeah, that's right the caps drain the image when the cables not used on a Gamecube. Removing the caps sorts the image out, hence why I did it.
    Since my first post I've had my Super Famicom Jr modified to output RGB, and the image quality is significantly better. The interference is still there, just less obvious. I'll try another cable once I pick a decent quality one up on the cheap.
  5. dj_johnnyg
    dj_johnnyg
    Not exactly 100% on-topic (so I apologise now), but would this mod be needed to use the RGB scart on the N64.
    Also, where are the Caps that need taking out.
    It's just these leads are on ebay for a couple of quid, and one modded for my N64 & SNES would improve my enjoyment no-end.
  6. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    Land of the Living, Essex
    +37
    No RGB for PAL N64 unfortunatly
  7. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    The caps are in series with the R, G, and B pins. And it would work on your N64, but you'd need to have it modded to RGB first, like I did with my Super famicom Jr.
