modified sony 725
Discussion in 'Blu-ray & DVD Players & Recorders' started by stranger, May 22, 2001.
  1. stranger
    stranger
    has played every r1 disc so far inc. t2 ult. edit matrix etc. having problems with charlies angels r1 rce, can get menu up and even run fbi warnings but then returns to dreaded map. plays all superman r1s. can any one help? thanks.nullnull[/LIST]null
  2. Guest
    Most Sony mods that are auto region only (cheap Sony mods tend to be the auto ones) won't play RCE discs.
    You could try putting another R1 discs in before to try to trick the player in to R1 mode but I am not sure if that works with the Sony players
