Modification on a pioneer 535
Discussion in 'Blu-ray & DVD Players & Recorders' started by tan1415, Feb 13, 2001.
  1. tan1415
    tan1415
    I finally made up my mind.
    Because of RCE the Tosh SD100E is not my choice,but it's the Pioneer 535.
    Only my problem is that i basically have 3 choices of a 535 and it has to do with it's modification.
    I have the choice of either automatic(cheapest),manual or automatic and manual(20pounds more expeensive) modification.
    The salesperson assures me that the automatic modifaction also works with RCE dvds.
    Is this true? I thought only machine with a manual modification is RCE proof.
    Well i hope someone can help me out.
    Thanks,
    DT
    PS the machine i am interested in is sold in mediamarkt in rotterdam. Anyone have this machine?
  2. Stick
    Stick
    The one I had, (for a few weeks!) was indeed selectble manually. There will be a leaflet in the box telling you your player has been 'modified' and lists a few discs that are found not to 'auto' select. It will then tell your how to select them. Quite a few button presses from memory!!!
    Stick
