Modest Home Cinema/Living Room setup
Discussion in 'Home Cinema Building DIY' started by phunkey_monkeh, Jan 19, 2008.
  1. phunkey_monkeh
    phunkey_monkeh
    Well, where do we start.
    Having not long had the house I put up with the terrible decor until I could afford to 'make it my own'.
    I've always been a huge cinema fan, and a bit of a technology geek. A home cinema setup of sorts has always been on the cards. And I’m now well underway to achieving my goal.
    To start with, the shape of my living room has always been a problem. With the large chimney breast and the windows and doors on every wall, I was never able to actually position a TV directly in front of my sofa and ended up with the TV in the corner. This annoyed my tremendously.
    Let me apologise beforehand if there are some gaps in the pictures...I kept forgetting to take pics.
    EQUIPMENT LIST
    Samsung 46" F86
    Sky + (soon to be replaced with HD)
    PS3
    Xbox 360 (soon to be replaced with Elite)
    Media PC
    Octavia 5x1 HDMI splitter
    Sanyo Z5
    Harmony 1000
    Sony HT-SS1100
    You may at this point ask why I’ve gone with such a low spec surround sound system.
    To be frank , I was running out of cash, I wanted small speakers to mount in wall, and I’ve never had a high spec system so hopefully I won’t know what I’m missing :p
    They should be much better than the standard TV speakers anyway.
    So let’s not hear anymore on the speakers :D
    This first pic is a quick knock-up of the current shape of the room including door/window locations and the chimney breast.
    The size of the room is approx 25ft x 15ft
    [​IMG]
    As you can see it didn’t really leave much room to work with.
    I decided to do away with the fire and create a stud wall to effectively box in one of the alcoves, and thus giving me a flat wall. I had also decided to create another stud wall on the other side so that the TV could be mounted in the wall.
    Something like this..
    [​IMG]
    I hope I’m making sense so far.
    The first obstacle was to remove the old fire...an expensive job it seems.
    The house was run by a back boiler...which meant that it I wanted to bin the fire i needed a new boiler.
    So after a bit of research the old fire was removed, and a Worcester condensing combi installed upstairs.
    [​IMG]
    [​IMG]
    I moved all my equipment down one end of the room so i could get to work on the stud walls .
    [​IMG]
    This is the wall that will eventually contain the tv/speakers.
    [​IMG]
    The stud wall was relatively easy to put up. I had to chisel out a hole in the chimney breast to accommodate one of the rear speakers (the hole is hidden by the plasterboard in the next picture)
    [​IMG]
    With one wall almost complete....
    [​IMG]
    This hole will eventually accommodate the Z5. Power points and cables have been run. I have also fixed the cables, as i don’t want to lose them in the cavity :eek:
    [​IMG]
    The finished wall..(almost)
    [​IMG]
    One rear speaker hole cut out
    [​IMG]
    Speaker and HDMI cable (for Z5) run
    [​IMG]
    Now onto the second wall.
    Frame completed and board starting to go on.
    [​IMG]
    [​IMG]
    [​IMG]
  2. phunkey_monkeh
    phunkey_monkeh
    Speaker holes cut out and plasterboard boxes made.
    [​IMG]
    [​IMG]
    It was at this point we realised the centre speaker was off centre by about 1cm.
    A bit of fiddling and it was moved.
    [​IMG]
    Both rear speaker holes created and cables run.
    [​IMG]
    Now, back to the horrible decor...patterned artex....it had to go.
    I felt dizzy looking at my ceiling.
    [​IMG]
    From the kitchen to the front of the room, please ignore the fridge..it will be gone this weekend.
    [​IMG]
    From the opposite direction.
    [​IMG]
    Ok, so we are nearly up-to-date.
    The plasterers came today to make a start.
    They have bonded and skimmed the ceiling and done some of the reveals. as well as putting the corner beading on.
    No more artex...
    [​IMG]
    You can still see some of the swirls from the artex if you look carefully. But they are not proud and should be gone when the skim dries.
    [​IMG]
    [​IMG]
    [​IMG]
    So that is where i am at the moment. Still quite a bit left to do. I’m really not looking forward to painting and i haven’t really decided on a colour scheme. Although my sofa is brown leather. So I’m guessing neutrals.
    The plasterers will be back on Monday/Tuesday to finish the walls.
    I’ve still got the skirting/architrave/rads/doors/flooring/lighting and more left to do. I’m hoping to be finished in the next month and now that I’ve started this post ill be sure to keep it updated.
    Anyways..sorry that was so long and if anyone bothers to read it...thanks :D
  3. HandsomeBWonderful
    HandsomeBWonderful
    Jan 26, 2006
    394
    +19
    Looking great so far PM. I will be keeping a watchful eye on your progress. :thumbsup:
  4. MitsiTurbo
    MitsiTurbo
    Jan 6, 2005
    940
    28
    Milton Keynes
    +82
    Very interesting read mate, well done. One thing I would have considered personally, you seem to have lost a fair bit of space with the new stud wall, maybe some recesses for DVD storage etc would have been worth doing?
    Will be keeping an eye on this one :thumbsup:
  5. phunkey_monkeh
    phunkey_monkeh
    hi,
    im am losing a bit of room with one of the alcoves. But its not as much as it may seem.
    Im losing a space of approx 1ftx9ft. But im gaining so much more 'wall space'
    The alcove was always wasted space before, for me at least.
    I dont plan on selling anytime soon, and with it being a stud wall it'll come down easy enough if need be. :)
    Also directly behind the TV wall is my cupboard under the stairs...all my equipment will be in there, out of the way .
  6. Gaz B
    Gaz B
    Aug 27, 2005
    33
    Leeds
    Good stuff, should be nice and smart when it's done. I like to see ones using limited space :)
  7. ANGUZ
    ANGUZ
    Mar 2, 2006
    383
    Boro
    +13
    Great work mate :)
  8. elootos
    elootos
    Jul 14, 2006
    316
    46
    Somewhere in Cambridgeshire
    +131
    That what this forum is here for!
    Glad to see someone else is venturing down the path to achieving their home cinema nirvana, good luck!
  9. phunkey_monkeh
    phunkey_monkeh
    Plastering is finished.
    Will post some updated pics tonight :)
  10. dj_woodster
    dj_woodster
    Jan 21, 2008
    60
    11
    Leicestershire
    +8
    looking very good, keep us updated :D
  11. phunkey_monkeh
    phunkey_monkeh
    As previously stated the plasterers have been and done their thing.
    Its starting to take shape now, and hopefully even more so when the paint is on.
    A couple of pics of the screen location with speakers in for effect. :D
    The edges may look a little wonky..
    It may be my camera, or it may be because the plaster is still wet and the different patches make it look uneven...but i reality the lines are perfect.
    [​IMG]
    [​IMG]
    A shot of the back wall. The sofa fits perfectly inbetween the two rear speakers (well about 10cm either side) and ofcourse the cubby for the Sanyo Z5 at the top.
    [​IMG]
    A close up of the projector cubby.
    You may have noticed from other pics that the right hand side of the cubby is not closed. This is because i want the PJ to have a bit of air to breath. So its got the whole cavity for that :)
    [​IMG]
    And lastly a longer shot of the 'tv wall'
    [​IMG]
    I suspect it may be a few days before anything else happens as im back in work on Wednesday. I've also yet to decide on the colour :)
  12. Festerfly
    Festerfly
    Nov 21, 2007
    547
    +29
    Very smart setup.. nice to see what you can do with a bit of room!
    I also am a gadget freak (sadly the budget doesnt always live up to my expectations!) but with some recent trading and acquisitions im almost there on all the bits i was after and shouldent be long until i do my wireup and such.. sadly no building work as we rent out property but will do what i can where i can etc!
  13. timtastic_bhoy
    timtastic_bhoy
    Dec 13, 2007
    82
    looks like your on your way..I wanted ot convert the basement to my cinema room but the trouble n strife said the £25k need to convert the structure was too much and the money could be better spent elsewhere.....shoes knowing her
  14. phunkey_monkeh
    phunkey_monkeh
    A little update.
    I've been ill for the past week so ive not really done as much as i had hoped.
    But i felt a bit better today so had a quick tidy, started laying the fibreboard and took some pics.
    A quick shot of the 'tv wall' All painting has now been finished (sort of)
    The colour wasnt exactly how i wanted, but its such a dark room.
    I live in a terraced property and the buildinds either side have large extensions out the back which block out alot of light. With that in mind i wanted a light colour. So its 'Soft coffee' or creamy beige for us common folk :p
    [​IMG]
    Another shot of the back wall, for some reason the back wall looks a different colour to the one on the side..it doesnt in reality...camera trick i guess.
    [​IMG]
    A closer shot of the tv wall.
    And yes i do intend to paint in the speaker holes...i just forgot about them :)
    [​IMG]
    Ive hung my old drh screen for the moment until the new one arrives...i wish i hadnt because the roller mechanism has gone and its a nightmare to roll back up. lol
    This is a 78" screen. My new one should be here in a few days and its a 98" electric remote controlled one.
    [​IMG]
    And lastly...my new lights. I love the effect they create on the ceiling.
    They are not very bright if im honest...10 x 10w bulbs. But there are two, and its bright enough. Especially when i add a lamp of some sort.
    [​IMG]
    Thats it for now.
    I've got a mate coming around with his core drill tomorrow to cut out a hole in the tv wall for the scarts to the tv. The bracket will be going up along with the tv.
    Keep checking back.
  15. phunkey_monkeh
    phunkey_monkeh
    A futher little update today.
    With the tv bracket being quite low profile i was concerned about clearance for the scarts and hdmi cables.
    So a mate offered to lend me his core drill...what a fantastic bit of kit. Perfect hole right through into the cupboard under my stairs.
    [​IMG]
    The removed cylindrical peice of concrete.
    [​IMG]
    Also got around to putting up the bracket.
    [​IMG]
    I decided not to mount the tv quite yet.
    The wall needs a clean and a bit of touch up paint as a result of todays work. I also need to add in my apollo LED kit.
    Might do all this a bit later.
    Im back in work tomorrow, so hopefully ill have some more updates over the weekend.
  16. thelawns
    thelawns
    Mar 7, 2005
    1,665
    +146
    Hello mate, where did you get those lights from, they look awesome! My light in my lounge has packed up, this would be an amazing repacement...? :confused:
  17. phunkey_monkeh
    phunkey_monkeh
    British Homestores mate.
    They were £150ea
  18. thelawns
    thelawns
    Mar 7, 2005
    1,665
    +146
    Cheers, just been on the website and can't see them... :(
    I don't think the shop near me in Derby does lighting either... :rolleyes:
  19. phunkey_monkeh
    phunkey_monkeh
    A few updates.
    [​IMG]
    [​IMG]
    [​IMG]
  20. phunkey_monkeh
    phunkey_monkeh
    I havn't done that much today.
    I've been up the tips a few times this morning trying to stop my garden turning into a waste ground.
    I've taken a screenshot of the actual led's for those of you who are interested.
    I may just use them for decorative lighting...i havnt decided, and wont until everything is finished.
    [​IMG]
    Also i had a large parcel delivered today ...
    [​IMG]
    [​IMG]
    [​IMG]
    I also took a few screenshot of the tv in place.
    These are just off freeview as i havnt hooked up any other sources yet.
    Im also pretty poor at taking photos of moving pictures, and my camera isnt great.
    The tv is also using its out of the box settings...which are horrible. But anyway, i digress.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    And also a side shot to show how the tv fits in the recess. (ignore the mess in my kitchen lol)
    [​IMG]
  21. Dextur
    Dextur
    Aug 30, 2004
    10,386
    +1,768
    That's really nice, going to look sexy as hell when finished.
  22. Jamie
    Jamie
    Jun 27, 2007
    5,291
    2
    Harrogate
    +1,368
    Lovely work. Only thing is I think you need longer apollo light bars as I think it ruins the effect not going all the way round. Although to be fair photos can be deceptive but I still think you need longer ones.
    Edit: Just seen your post on the apollo thread and it seems you agree about more light bars. Love the rest of the job so far. I'm getting itchy to start mine now but apparently the kitchen is a priority. Well I did tear the wall down a year ago and done nothing since so fairs fair :)
  23. Fieldling86
    Fieldling86
    Jan 3, 2008
    61
    +4
    Very nice job.
    How deep have you made the recess so as to make the TV flush with the face of the corner unit?
    Per
  24. phunkey_monkeh
    phunkey_monkeh
    This is the little room under the stairs that will house all my equipment.
    Such as
    Vista HTPC
    PS3
    Xbox 360
    Sony Amp
    Octavia 5x2 hdmi/optical splitter
    3tb online storage.
    Sky+
    [​IMG]
    The back end of the room, the washing machine will be coming out (hopefully tonight)
    [​IMG]
    The top end where the shelves will be
    [​IMG]
    This is the back view of the core drill hole behind the tv to accomodate cables.
    [​IMG]
    And a close up shot inside the hole...as you can see if fits perfectly with the AV panel on the TV.
    [​IMG]
    I've just this minute given the room a quick coat of paint. Ill be doing a 2nd coat a bit later.
    Im painting it the same colour as the living room.
  25. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    Well well well... is this phunkey_monkeh of Cliosport fame ? :)
    I have to say, this is looking fantastic mate ! :)
    Hope things are good with you !
    Dai
  26. phunkey_monkeh
    phunkey_monkeh
    haha, small world mate.
    How's things?
    A few little updates.
    Nothing that exciting tonight.
    I got my new screen up. Its 100" diagonal (near enough)
    [​IMG]
    I thought id take a few screenshots of the unit in action.
    Ive not yet changed any of the settings as the bulb hasnt wore in yet. But its pretty decent out of the box to be honest.
    Excuse the wonky pics, i have so much stuff around the place i can barely move at the moment.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  27. phunkey_monkeh
    phunkey_monkeh
    I've spent most of today cleaning to be honest...the dust is a right pain.
    I've fitted the speakers and cables to said speakers.
    [​IMG]
    I've also finished painting in the little room.
    You may still be able to see a few bits of yellow (namely a waste pipe and phone cable) both will be removed shortly.
    [​IMG]
    My cable mess at the moment (and thats only the leds, aerial and speaker cable :/)
    [​IMG]
    Some shelbing...more to go up when ive painted them.
    [​IMG]
    Before starting on my living room i was doing my kitchen, which is directly next to my living room (small terraced house in south wales lol) I still have a few bits to do in here.
    but here is how it stands at the moment
    [​IMG]
    Also my 23" sammy tv.
    [​IMG]
    I'll come onto the cables in a moment.
    [​IMG]
    You may notice that this wall in the kitchen is directly behind the little room.....so yes. Im going to be drilling through into said room and feeding power cables and the like.
    [​IMG]
    Really hoping to get the floor down this weekend....fingers crossed.
  28. wandgrudd
    wandgrudd
    Dec 16, 2002
    184
    Nottinghamshire
    +7
    what the title's of the above moves being shown?
  29. phunkey_monkeh
    phunkey_monkeh
    First two are Hitman, third and forth are Beowulf.
    Both are trailers via the PS3
  30. thelawns
    thelawns
    Mar 7, 2005
    1,665
    +146
    Managed to go into BHS. Couldn't see those lights unfortunately! :(
