Modem driver help
Discussion in 'Desktop & Laptop Computers Forum' started by GCDB, Jun 1, 2005.
  1. GCDB
    GCDB
    Sep 23, 2004
    320
    Wrexham
    HI,
    I have upgraded to xp and cant get the modem to work.Anyone know where i could get a driver for the following.
    Intel chipset modem
    Mentor...make?
    v.92 fax modem
    ITU-T v.92
    Hayes AT command compatible
    Tried looking on web with driver searches etc
    Any help appreciated or will have to buy another modem.
  2. mrmoo
    mrmoo
    Jan 10, 2005
    515
    +20
  3. GCDB
    GCDB
    Sep 23, 2004
    320
    Wrexham
    thanks for that website,useful.The only other problem i have is that when i set my pc to shutdown,it then re-boots automatically and the only way i can turn it off is by the plug. Is there a setting in the bios or something i need to alter as it is a bit frustrating.
  4. mrmoo
    mrmoo
    Jan 10, 2005
    515
    +20
  5. GCDB
    GCDB
    Sep 23, 2004
    320
    Wrexham
    Thanks for post, but played around with bios settings last night,altered Lan setting? and system crash settings(kept note of what i changed) and this hopefully seemed to sort it out as i can shutdown windows and it turns itself off now and re-boots when powering up as normal.But thanks anyway and have looked at site. :thumbsup:
