Modded Xbox
Discussion in 'Xbox Forums' started by StinkyPete, Nov 1, 2005.
  1. StinkyPete
    StinkyPete
    Sep 12, 2005
    387
    +79
    I have a chipped xbox, it was chipped so I could play imported games and has a switch on the front with a light so I can turn the chip off if I want to go on line.
    My question do I need to soft mod in order play in hi-def mode using component, I have a panny 42pe50 arriving on Thursday (I know its not true HD but it will scale down) or can I just get some good cables and it will work fine.
  2. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    no you dont need the softmod the chip is fine. what you need to load is the enigma video switcher and turn your xbox from PAL to NTSC. then in the dashboard video options 720p and 1080i becomes selectable
  3. holtehero
    holtehero
    Sep 10, 2002
    2,854
    Cambridge
    +1,776
    Will it stay on NTSC with the chip off though?
  4. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    +76
    yes, im not totally sure but i think its something to do with the eprom ??? but im sure it stays as NTSC when you change it with a chip installed. think CAS has his modded like this so ask him via PM or hope he see's the thread (which he will)
  5. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Yep it stays on NTSC mode when the chip is deactivated - hope that helps :)
  6. holtehero
    holtehero
    Sep 10, 2002
    2,854
    Cambridge
    +1,776
    Thanks, wish i didn't have the larger hard drive now else i could have used it on live
  7. StinkyPete
    StinkyPete
    Sep 12, 2005
    387
    +79
    How do I load the enigma video switcher, do I download this and put it on CD and insert in the Xbox??
  8. richard plumb
    richard plumb
    Jan 27, 2002
    14,551
    Windsor
    +1,056
    you can still use it on live if you have your chip turned off. Hard drive size doesn't make any difference. I actually wish I'd gone for a bigger one than the 40GB I have in there!
  9. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    +76
    ive heard of lots of stories about being banned for a none standard HDD. something to do with the HDD you had in when you signed up to live.
    Stinkypete i honestly dont know i softmodded mine so you will have to find out www.xbox-scene.com will tell you all you need to know
  10. StinkyPete
    StinkyPete
    Sep 12, 2005
    387
    +79
    Cheers Kopite, its been a while since I have been in EVOX and just can't remember how I do it, I will have a go when I get home, maybe it will all come flooding back when I do.
    By the way, what is happening with our boys, are we jinxed in front of goal or what?
