modded xbox & xbox live
Discussion in 'Xbox Forums' started by holtehero, Oct 14, 2004.
  1. holtehero
    holtehero
    Sep 10, 2002
    2,780
    Cambridge
    +1,778
    Just about to sign up for xbox live and my current xbox has an Xecuter 2.1 (i think) which has an external disable switch that allows me to disable the chip and go to the normal M$ dashboard, It also has a 40Gb hard disk.
    Now am i correct in assuming that if i disable the chip with the switch on the side then i should be able to use this with Xbox live?
    Just heard lots about eprom barring and potential HD scans and wondering whether i should consider buying another unmodded xbox for live play
  2. EffTee
    EffTee
    Jan 20, 2002
    196
    Bristol
    +5
    holtehero,
    There's always lots of talk about what Microsoft can and can't check for. At the end of the day you just have to go on peoples experience - there are a lot of people (me included) who successfully turn their chips off and play on live with no problems.
    If you do get banned you can just revert to plan B and buy that nice new Crystal :)
    EffTee
