modded Xbox - games from HD
emad
Banned for trading fraud
I have an unmodified XboX connected to my Plasma via MS HiDef kit.
A friend/forum member came to visit me this W/E with his modded XboX and we copied my GTA3 Vice City from my CD to his HD but the game would not play in eithe PAL or NTSC modes. His other games however were playing of the HD just fine.
When he returned home, he called me confirming that GTA3 is working fine on his TV connected using RGB Scart?!!!
Can any of you guys tell me what is going on here??
I am trying to make a decision of modding my XboX but why wouldn't GTA or any other Game work from the HD?
Emad
supersonic87
What you have done is illegal and although I could help, I won't due to the fact you are helping your friend to STEAL material from games companies, if you want to mod your XBox for backing up YOUR own games ok, but dont steal from games companies who often pass this bill onto us (the PAYING comunity).
Rich
emad
1 - My friend copied the game on his xbox to check if the connection is the cause of the problem rather than the game itself.
2- I do not need you to tell me what is legal and what is not as I am well aware of this.
3-If my friend wanted to steal a game - there are 10000 place that rent all sorts of games!!!!!
4- I don't think you can help.
Emad
buzlightyear
I believe if you were making a backup would you not have to patch it once on the xbox hard drive?
emad
buzlightyear
what do you mean patch it?! If you backup your game from your disc, don't you just copy it?
Emad
james.miller
no, you patch it.
buzlightyear
sorry must of been getting confused with something else, think you need to do that when you want to put it back onto DVD.
Messiah
When you copy a game from DVD to the HDD the loader program should automatically patch the relevant xbe files. Were you using DVD2Xbox or PX HDDLoader? If you were copying directly using one of the file manager programs then the xbe files would not be patched and the game would not play.
emad
Thank you Messiah, I am not sure how it was copied. My friend was just showing me the benefits of getting the Xbox modded but I didn't catch how he copied it.
I will ask him and see if it was using a file manager program or HDD loader.
Emad
Messiah
OK. Feel free to PM if you have specific Q's. Do a lot of stuff with Xbox modding so I know a little about it ;)
Smurfin
And games would be cheaper if there was no pirating? Riiiiiight....
richard plumb
surely the patch is irrelevant, as his friend had the game working at home?
Maybe its a problem with supporting the Hidef pack?
If your friend doesn't have a hidef pack at home, then maybe his dashboard/games aren't set up for that, and that caused some problems?
emad
Thank you Richard
I am beginning to think it is the GTA3 as all other games played fine with my HiDef pack!
Justinrog
GTA 3 original game disc has a problem if I set my Hi-Def pack to widescreen and 480p. Half the screen goes missing and it is unplayable, a change to fullscreen in the dashboard gets rid of the problem. I imagine the backup to be the same. This is the first game I have encountered that does this.
Hope this helps,
J
emad
Justin
I think you've just solved my problem. This is exactly what happened with the game on my friend's modded xbox. HOWEVER, my Un-modified XboX plays the game just fine even though it is set to Widescreen in MS-Dashboard!!
I have mine always set to Widescreen as I play Burnout 2 which won't play unless the setting is Widescreen. Puzzling
Emad
emad
V5 Bingo
So it will work with Widescreen & Interlace
And
it will probably work with Full screen & progressive
But
won't do Widescreen & Progressive.
Justinrog
Yep, I have the same problem. I think its something to do with the hi-def kit and this game and widescreen all together. Very strange anyway!
J
Podcast: Cleer Audio speaker + HiFi Rose Streamer Reviews & Movie/TV Show talk
