Modded X Box
Discussion in 'Nintendo Forums' started by stormjai, Aug 29, 2004.
  1. stormjai
    stormjai
    Nov 15, 2003
    331
    Bromley
    +3
    Now that the XBox has finally come down under £100, thinking of taking the plunge. Already have PS2 and GC.
    Where is best place to get modded xbox - hopefully price down as well!
    Which Mod best/most useful - will need to allow backup game play, hi-def if possible (to connect to hi-def display)
    Any suggestions appreciated.
    Thanks :hiya:
  2. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
    Why would you need it to play backups? :rolleyes: (stupid question, I guess)
    All modchips bypass region and copy protection so this wouldn't be a problem and they should all allow you to play games in high definition. Executor 2.3b is probably the best value chip to buy
    The only difference between chips is for stuff like homebrew support, writing your own bios settings etc - they all do the basic stuff, and do it as well as each other
