modded 360 black and white
Discussion in 'Xbox Forums' started by shoman6995, Jan 6, 2012.
  1. shoman6995
    shoman6995
    Jan 6, 2012
    ok when i was deployed in Iraq i bought an xbox from them it worked fine while i was there. i shipped it home and when i get home to play it it turns on black and white. the movies sometimes scroll. i have checked with 5 diffrent tvs and used 4 diffrent connections. when i was there i bought a game from the and it downloaded the kenects thing and then i was not able to play black opps any more maybe something diffrent who knows but it is really kicking my butt.:lease: help
  2. bearman3784
    bearman3784
    Dec 18, 2007
    5,813
    Hitting the Eastside of the LBC
    +1,649
    When you say modded, as in flashed to play pirated games?
  3. Doug the D
    Doug the D
    Oct 16, 2010
    8,483
    Dorset
    +13,450
    When you say you bought it Iraq, who did you buy it from (nationality-wise). Iraq works on the same TV standard as here in the UK (PAL), whereas the US works on the NTSC standard. If you brought the Xbox from a US soldier (or swapped it for a cap-badge lol, you know what they're like!) then on standard def the xbox wont work on a UK telly. If you are using it in Hi-def, it won't make any odds. Hope this helps. If its a hacked xbox, then the latest updates will have stopped you from playing your copy (?) of Black Ops - I assume that you weren't online in Iraq? Retail copies of games will work with your xbox. Hope this sheds some light for you...
  4. Rorifett
    Rorifett
    Mar 23, 2008
    24,859
    Sunny Scotland
    +15,237
  5. Crovon
    Crovon
    Apr 29, 2006
    5,112
    In a 4G, inverted dive, with a MIG28.
    +824
    What about trying the VGA cable, would that get around the NTSC issue?
  6. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    36,566
    Bristol
    +9,374
    VGA will only output in 60hz on the 360.
