crunchynut
Hi all,
I’m looking for some advice from electronics guys or gals please.
I have a MusicalFidelity M3si integrated amplifier. It works great and I’m very happy with it, driving a pair of Focal Aria 905 speakers.
However, having bought an RME ADI-2 DAC FS which serves as an excellent pre-amp with a powerful DSP, I thought I would try driving the power amp in the M3si directly. So I disconnected my AVR that was connected to the HT input and plugged the line-out from the DAC into it, then did some back to back tests. The outcome is that directly driving the power amp is markedly better - for example vocals are much more clearer - even a normally cynical family member spotted the difference without being told what to look for.
So - that’s the next mod for me to make. But the problem is I still want to make use of the HT input for my AVR. So I took the lid off the amp to see how it was wired, hoping it would be a simple relay switching arrangement that bypasses the pre-amp and connects directly to the power amp. If so, then I’m competent enough to replicate it and convert one of the other inputs to do the same. Unfortunately the input selection is via a microprocessor controlled analogue switch IC, so not possible without circuit diagrams and ability to change the code in the cpu to replicate how the HT input is routed. But it is also apparent that the HT input still goes through some aspects of the pre-amp, even if it is just the switch IC, which isn’t ideal for what I’m trying to achieve in bypassing all pre-amp effects.
Given this, the question I have is whether I can disconnect the leads that go from a socket in the pre-amp over to the power amp (a very obvious pair of 2 channel leads about 8 inches long) and build my own 2 in 1 out switch, using some quality signal latching relays that connect straight to it? Putting a relay in the signal path isn’t ideal but it may well be superior to use of a switching IC (separation / isolation for example).
I’d be grateful for any input from people who know.
PS I could buy the M6s PRX that achieves exactly what I want, but it’s overpowered for my needs and costs £2600!
