Mod Chip for XBox?
Discussion in 'Xbox Forums' started by DazJWood, Oct 5, 2003.
  1. DazJWood
    DazJWood
    Jun 13, 2002
    176
    19
    Coventry
    I am new to the XBox having just bought one two days ago.
    I am thinking about getting it modified with one of these chips. Anyone got any suggestions as to which ones are the best? I hear these Xecutors are good.
    What about these solderless ones too? Are these any good?
    I have chipped many playstation 1s in the past, but the xbox looks a lot more complicated to chip (solder chips). Is this the case or is it fairly straight forward?
    Any advice would be appreciated,
    Daz
  2. phenom2003
    phenom2003
    The chip itself is relativly easy to fit, however you will need to flash mosts' bios (Xecuter2.1/2.2). The solderless ones are best avoided. have a look at www.baldbouncer.co.uk and the forums on www.worldxbox.com for any more advice.
  3. Paden
    Paden
    Jul 27, 2000
    572
    +19
    phenom2003, does this envolve connecting the X-Box to a pc or does it upload from a cd or something?
    Cheers, Paul
  4. phenom2003
    phenom2003
    You can flash from a pc or an external programmer. The most popular option however, is slayers auto installer disc, which does the hard work for you (flashs bios, new dashboard, HDD swap). I can send it to you if you want just ask for it when (if) you reply
    Rich
