Mobo for Antec fusion case?
Discussion in 'Desktop & Laptop Computers Forum' started by Nokmondoo, Sep 19, 2007.
  1. Nokmondoo
    Nokmondoo
    Jan 22, 2006
    1,816
    +98
    hi all, just about to start ordering some bits for my first htpc. Can someone recommend a decent but cheap mobo to fit a antec fusion case? Will be getting a decent graphics card, maybe X1950 PRO 512MB, so don't need onboard graphics. Need to output spdif, dvi and vga.
    Just a side note, will the above card or 7900 for eg fit the case? Thanks again.
  2. Zarch
    Zarch
    Jan 23, 2003
    3,577
    Sheffield
    +833
    Foxconn P4M9007MB-8RS2H Socket 775 P4M900 onboard VGA DDR2 mATX, £34 inc vat
    http://www.ebuyer.com/UK/product/126717
    Got this in mine, no probs at all. its got spdif and you just disable the onboard graphics and bang your pci-e gfx card in it!!
    Check out my full thread for details etc.
  3. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    I bunged a 8500gt card in mines - not for gaming just wanted enough grunt for Hidef later on,.
    On a side note the case is so cool and gained other half approval :thumbsup:
