Mobile phone as car DVR
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Jaded, Aug 28, 2013.
  1. Jaded
    Jaded
    Oct 23, 2005
    62
    Hi. I want to avoid messy wiring. Can anyone recommend a non-fancy phone that has decent quality video front and back? Grateful for alternative thoughts. J
  2. martUK
    martUK
    May 22, 2007
    655
    28
    +66
    You'll have just as much wiring with that as you'll need to keep it on charge. Also unless there's an app already you'll have to find something that can record from both cameras at same time, overwrite once memory is full, maybe date/time/speed stamp the recordings and a nice way of mounting it. In all it would be almost as cheap and much less hassle to get something that is designed for the job.
  3. Jaded
    Jaded
    Oct 23, 2005
    62
    T F R. I understood that some of the modern phones had 'on times' of some hours, but perhaps that is not in recording mode?
