Mobile Me Problems
Discussion in 'Apple Forum' started by baldrick, Feb 5, 2009.
  1. baldrick
    baldrick
    Dec 28, 2002
    3,370
    Providence, Rhode Island
    +246
    Is anyone else experiencing any problems with MobileMe? The web interface is fine but my iPhone and Mail on my Macs can't connect, I'm getting a 'time out on port 993' error!?!?!
    EDIT - It appears to be an issue when I try to connect via my home network. I just walked into town and my iPhone could check mail happily over the mobile network! I've just restarted my router, but this doesn't appear to have solved the problem?
  2. baldrick
    baldrick
    Dec 28, 2002
    3,370
    +246
    Additionally Adium can't connect to MSN, my accounts are all stuck at 38% 'Handshaking'!?!?!?
  3. spinaltap
    spinaltap
    Oct 3, 2004
    2,789
    Birmingham
    +1,356
    In your router, have you entered the MAC address of your iPhone (and of the airport card in your Macintosh) in its security panel - together with the ip address of both in the 'LAN IP Setup'?
  4. baldrick
    baldrick
    Dec 28, 2002
    3,370
    +246
    A factory reset of my router solved the problem. Zen technical support suggested it as a way to clear down the NAT tables which he thought might have gotten scrambled.
    Adding the MAC addresses is only necessary if you want to completely lock down a WiFi network.
