meansizzler
Using Vista 64 Bit..
When I have my Windows Mobile Phone synced to the pc via the Mobile Device Center and close media player 11 after listening to a song or playing a video I can still hear it playing in the background, even after unplugging the phone..
If the phone is not connected/synced at all with the pc then everything works fine, experienced this problem before with Win XP and Active Sync Latest version, the fix I found was to Disable the "Sync Media Files" option in active sync, but this feature is not present in the mobile device center, anyone have a solution? the problem in xp was experienced on a different computer so not alone on this.., anyone else experienced it or can test it out?..
Can't seem to find a solution when searching the microsoft discussions/newsgroup...
The only way to fix it is to disable USB Sync on the Device so I can connect the phone to charge via USB but I can't sync it or access it..
Maybe it is Soundblaster related?..but not sure why it happens with Activesync and Mobile Device Center using different computers...
