Mobile Broadband and Windows 10?
Discussion in 'ISPs & The Internet' started by williamus, Jun 8, 2016.
  1. williamus
    williamus
    Feb 6, 2009
    929
    46
    Birmingham
    +142
    I'm about to buy a new tower desktop which will have Windows 10 installed. I've used Three MBB dongles successfully with Vista and Windows 7 which have always worked plug-in-and-play. The dongle I'm currently using is the
    ZTE MF823 4G dongle - Mobile Broadband - Three
    I can't think of any reason it shouldn't work though there's quite a bit of noise on the net about its compatibility with W10. Disappointingly my local Three shop said they weren't sure but "probably not". I haven't rung Three yet because I'm not sure the scripted format with help my enquiry.
    Has anyone here tried the combination (or similar) or know for certain that it runs (or not)? Many thanks
  2. AciidSn3ak3r
    AciidSn3ak3r
    Jul 9, 2007
    679
    Leeds
    +75
