Oh dearly beloved AV Forumers, I know you can help.
I have obtained serveral movies in MKV format. I can play them on my PC fine, but want to play them on my TV.
My PC is nowhere near my TV, so a direct connection is out the question. In the past I used to stream AVIs across my wireless to my PS3, but always had problems with buffering as my connection isn't very good.
In the past I have copied my AVIs directly onto the PS3 HDD, and played them without any issues. I was hoping to do the same with the MKV's, but apparently PS3 won't recognise the format?
So after a bit more digging I have stumbled across MKV 2 VOB. Can someone tell me, if I simply convert them to MPEG, will they play on the PS3 OK? The file size to begin with is aprox 10GB for each film, give or take.
Or if anyone has any other suggestions it would be appreciated.
