MKV Video Playback Problem - GT50
Discussion in 'Plasma TVs Forum' started by ymisyd, Aug 22, 2013.
  1. ymisyd
    ymisyd
    Jan 24, 2008
    89
    Woking
    Hello,
    I have ripped some of my Blu-Ray discs using MakeMKV and they seem to have ripped fine with no problems. However, I do have a strange playback problem on my Panasonic GT50.
    Some films exhibit a breaking-up / pixelating of the picture on playback, either through my wired network connection or via the use of a USB stick plugged directly into the TV (picture attached). Strangely, my Panasonic Blu Ray player won't play the files over the network (they appear to be unsupported?) but plays them perfectly with the USB stick plugged into it.
    To sum up, it would appear that the TV itself is having some kind of trouble with random discs (the screenshot is from Django Unchained, but Dredd and Hot Tub Time Machine work perfectly whereas The Other Guys exhibits the same problem)
    Many thanks in advance for any help....
  2. ymisyd
    ymisyd
    Jan 24, 2008
    89
    Woking
    Anybody else experienced this....?
  3. ymisyd
    ymisyd
    Jan 24, 2008
    89
    Woking
    Any help appreciated.....
  4. ymisyd
    ymisyd
    Jan 24, 2008
    89
    Woking
    Anybody experienced this on any other TV? Would moving this post to a different forum help?
    Many thanks......
  5. ymisyd
    ymisyd
    Jan 24, 2008
    89
    Woking
    Anyone?
  6. Veky
    Veky
    Jan 26, 2014
    2
    4
    Hi, sorry for bumping an old thread.
    I'm having exactly the same problem with my GT50.
    Almost every other MKV has this problem and it always starts occurring at 10 minutes play time.
    I'm using Serviio for streaming but the same thing happens when playing via USB HDD.
    Does anyone have any idea how to fix this?
    Thanks in advance.
  7. beadlesabout
    beadlesabout
    Mar 5, 2007
    221
    28
    +35
    What size are the files that do this?
  8. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,101
    Croatia
    +136
    I'd recommend running the "rip" through mediainfo software and attaching/posting what it reports here...
  9. Veky
    Veky
    Jan 26, 2014
    2
    4
    Between 900MB and 4GB.
    I've re-encoded the same file using HandBrake and this one plays fine.
    Here is the info:
    Code:
    General
    Unique ID                                : 252892766115830257673805045289389622502 (0xBE4160066E8208AB8B938DAC28AF84E6)
    Complete name                            : F:\DLNA\doesnt_work.mkv
    Format                                  : Matroska
    Format version                          : Version 4 / Version 2
    File size                                : 900 MiB
    Duration                                : 2h 14mn
    Overall bit rate                        : 939 Kbps
    Movie name                              : doesnt_work
    Encoded date                            : UTC 2014-01-09 00:57:53
    Writing application                      : mkvmerge v6.6.0 ('The Edge Of The In Between') built on Dec  1 2013 17:55:00
    Writing library                          : libebml v1.3.0 + libmatroska v1.4.1
    Video
    Format                                  : AVC
    Format/Info                              : Advanced Video Codec
    Format profile                          : [email protected]
    Format settings, CABAC                  : Yes
    Format settings, ReFrames                : 4 frames
    Codec ID                                : V_MPEG4/ISO/AVC
    Duration                                : 2h 14mn
    Nominal bit rate                        : 873 Kbps
    Width                                    : 1 280 pixels
    Height                                  : 536 pixels
    Display aspect ratio                    : 2.40:1
    Frame rate mode                          : Constant
    Frame rate                              : 23.976 fps
    Color space                              : YUV
    Chroma subsampling                      : 4:2:0
    Bit depth                                : 8 bits
    Scan type                                : Progressive
    Bits/(Pixel*Frame)                      : 0.053
    Writing library                          : x264 core 135 r2345 f0c1c53
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=873 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Default                                  : Yes
    Forced                                  : No
    Audio
    Format                                  : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                          : HE-AAC / LC
    Codec ID                                : A_AAC
    Duration                                : 2h 14mn
    Channel(s)                              : 2 channels
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 KHz / 24.0 KHz
    Compression mode                        : Lossy
    Language                                : English
    Default                                  : Yes
    Forced                                  : No
    Code:
    General
    Unique ID                                : 172984831807522022751153958779030096498 (0x8223AAB025A08845293715DA30404A72)
    Complete name                            : F:\DLNA\does_work.mkv
    Format                                  : Matroska
    Format version                          : Version 2
    File size                                : 1.61 GiB
    Duration                                : 2h 14mn
    Overall bit rate                        : 1 719 Kbps
    Writing application                      : HandBrake 0.9.9
    Writing library                          : libmkv 0.6.5
    TITLE                                    : does_work
    Video
    Format                                  : AVC
    Duration                                : 2h 14mn
    Height                                  : 536 pixels
    Color space                              : YUV
    Bit depth                                : 8 bits
    Writing library                          : x264 core 130 r2273 b3065e6
    Encoding settings                        : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=14000 / vbv_bufsize=14000 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
    Language                                : English
    Default                                  : Yes
    Forced                                  : No
    Color primaries                          : BT.709
    Transfer characteristics                : BT.709
    Matrix coefficients                      : BT.709
    Audio
    Format                                  : AAC
    Format profile                          : LC
    Codec ID                                : A_AAC
    Duration                                : 2h 14mn
    Language                                : English
    Default                                  : Yes
    Forced                                  : No
  10. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,101
    Croatia
    +136
    All I can spot is the difference in format profile and bitrate...perhaps bitrate is too low and the TV doesn't like it...
    perhaps some tweaking in makeMKV is required to get this right...
