I own a philips cineos 42pfl9532/98 lcd, also a philips dvd home theatre system HTS8140 and a xbox 360
and none of them can play a mkv file through their usb slots.Xvid is fine but no mkv and since all my questions are relating with this subject matter i am going to divide them accordingly.
1.Is there any way i can get these files to play in any one of the selected media and if conversion or any other method is a possibility i would like to know what i will be loosing in the process.I know quality is a given but anything else i should know about.
2.I thought of burning some the files into a dvd 9 and maybe my player will support that but in case of files larger than 8 gb that's not possbile.
3.I use a simple method for applying subs, i just rename the file according to the main file and it works.Is this how it also works for MKV files.
Thanks to anyone who can help.
