Question MK, XTZ, Dali or ???
Discussion in 'What Speakers Should I Buy?' started by Chrisb, Jan 22, 2017.
  1. Chrisb
    Chrisb
    Jan 7, 2014
    69
    +36
    Hi All,
    I am in a very lucky position of looking to buy some speakers for a 7.1 or 7.2 setup.
    They will be powered by an Arcam AVR 550.
    It is a big room to fill, 6x7m with the ceiling at 2.8m.
    They will be used for mainly watching movies and dancing to music.
    I really want an on wall solution, apart from the sub(s) as we have little munchkins running around, and they love dancing! (I've already put a mirror ball on the ceiling!)
    I have an acoustic screen, so thats ok, but the sides and rears will need to be mounted relatively high, probably at about 2m.
    My budget is £5-6k.
    I was considering MK (MP150), but I think they are a little out of my budget, so then started looking at the XTZ cinema range. The trouble is to get to listen to any of these is at least a 6 hour round trip!
    (Why do these manufacturers so limit the stockist??)
    Dali Opticon (on wall) were another option, or Goldenear.
    Also are bi-poles/tri poles the way to go at the sides or not?
    I'd be really grateful for any advice.
    Many thanks,
    Chris
  2. Deleted member 598831
    I'm in preston lancs if you want to listen to the xtz cinema. check my sig for equipment.
  3. Chrisb
    Chrisb
    Jan 7, 2014
    69
    +36
    That's very kind but I'm in Dorset.
  4. Deleted member 598831
    Oh, sugar. If you post on the xtz thread, maybe ask if there are any owners down your way?
  5. richardsim7
    richardsim7
    Nov 19, 2014
    2,919
    2
    London
    +2,304
    Hmm, yeah, @Jag @ Epic Home Cinema is quite far from Dorset, but if you do decide to buy them, it'd certainly be worth the trip! :)
    Maybe make a day trip out of it or something?
    Can't remember who but I was fairly sure there's someone with an XTZ setup out west...
    As for your other question, I use S5s (the tripole ones) at the sides and it works incredibly well
  6. Chrisb
    Chrisb
    Jan 7, 2014
    69
    +36
    That's a good idea, thank you.
  7. Jag @ Epic Home Cinema
    Well-known Member AVForums Sponsor
    Jun 2, 2014
    1,778
    146
    Langley, East Berkshire
    +2,245
    Hi Chris, appreciate I'm not down the road but as stated, you'd be welcome to pop over and perhaps make a day of it. Windsor is a few minutes away and there are some great places for lunch. You can even take away the Cinema series when you visit thereby saving on delivery costs. Listening to the system optimally set up in 2 rooms plus discussing your system in person has some value to it too.
    Out west you have Allan - forum member Uptheowls who owns the Cinema series. Worth getting in touch. Alternatively, as suggested above, do feel free to drive down for the day.
  8. Chrisb
    Chrisb
    Jan 7, 2014
    69
    +36
    Thanks Jag, I'll drop you an e-mail.
    Any one any comments to make about MK, Dali, Goldenear? Any comparisons?
    Thanks.
  9. Saul Goodman
    Saul Goodman
    Jul 24, 2012
    1,356
    116
    +1,009
    Imo the XTZ cinema series would be my choice, you can't really go wrong with them.
    They have a fabulous reputation on here for both movie and music performance.
    You will get excellent advice and service from [email protected] too.
  10. AudioVisualOnline
    AudioVisualOnline
    Dec 4, 2008
    1,683
    116
    5 The Sidings, Bacup, Lancs, OL13 9RW
    +792
    We have both Dali and MK here and Im a big fan of both. If you want to hear any of them before deciding what to buy, and youre close enough to us, youre welcome to come and have a listen and see what you think.
  11. Chrisb
    Chrisb
    Jan 7, 2014
    69
    +36
    Thank you, but I'm in Dorset, there seems to be a lack of enthusiasts here!!
  12. richardsim7
    richardsim7
    Nov 19, 2014
    2,919
    2
    London
    +2,304
    Lucky you, you get the be the first one then ;)
  13. AudioVisualOnline
    AudioVisualOnline
    Dec 4, 2008
    1,683
    116
    +792
    There is an M&K dealer in Newbury if thats close enough, they dont do Dali as well though.
  14. richardsim7
    richardsim7
    Nov 19, 2014
    2,919
    2
    London
    +2,304
    Newbury is on the way to Slough, 2 birds, 1 stone? :)
    Probably beneficial if you heard both speakers on the same day too
  15. Chrisb
    Chrisb
    Jan 7, 2014
    69
    +36
    Thanks Richard, I may have found someone nearby with XTZ, fingers crossed.
  16. Rock Danger
    Rock Danger
    Oct 10, 2007
    11,197
    2
    Belfast - Northern Ireland
    +4,896
    Not from Dorset tho geography king. But you're an hour from where stay in London - I'll still take you up on a dem later on in the year. I'm over in Feb but have to teenager mind mostly.
  17. richardsim7
    richardsim7
    Nov 19, 2014
    2,919
    2
    London
    +2,304
    Yeah it is, it's basically a straight line :p
    And sure, just let me know :smashin:
    • Like Like x 1
    • Thanks Thanks x 1
    • List
