mk toughplugs
Discussion in 'Cables & Switches' started by miggsy, Oct 28, 2005.
  1. miggsy
    miggsy
    where can i get the mk tough plugs from??
    i went in b&q but there's was a duraplug
    any info :D
  2. deanym
    deanym
    May 29, 2004
    1,833
    +143
    Duraplug is just as good. You'll have no performance difference between the two.
  3. miggsy
    miggsy
    cool ok next question where sells silver fuses??
  4. deanym
    deanym
    May 29, 2004
    1,833
    +143
    Check RS components and cpc farnell. Google both the names, you should get some bites.
  5. lscolman
    lscolman
    Jul 31, 2003
    7,189
    Tyne & Wear
    +161
    Hi Miggsy,
    I believe Mark at www.the-missing-link.net can supply silver fuses. If not, I believe I have some.
    Cheers, Lee
  6. miggsy
    miggsy
    hi lee i will send a pm
