MK Toughplugs - are they different to all the other plugs?
Discussion in 'Cables & Switches' started by Timmy C, Oct 27, 2004.
  1. Timmy C
    Timmy C
    Oct 10, 2003
    5,110
    +382
    I've been reading a lot about peoples mains cable diy efforts and have notice a lot of people mention MK Toughplugs. I was wondering if anyone could tell me if these are in anyway better than the standard plug I may find in my local Sainsburys. A toughplug in B&Q is over £3 whereas a plug in Sainsburys is a little over 50p! £3 isn't a fortune but I don't see the point in buying them if they aren't going to make a difference!
    If anyone knows about these things then please let me know as I'm considering puting together a cable soon.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I think you have just answered your own question my friend...... In that case you might as well use the freebie lead that came with the plasma!
  3. Timmy C
    Timmy C
    Oct 10, 2003
    5,110
    +382
    Have I?
    Are you saying the plugs don't make any difference or the cable itself won't make a difference? I've had a quick demo of my friends expensive ready made mains cables and there's no doubt in my mind they changed the sound but my question is does the plug on the end of it have any effect or is it the cable itself. If the plug has an effect then will an MK plug be better than a Woolies plug at 1/5th the price as they all have the same shape pins and appear to be made from the same stuff?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    the point of a mains cable upgrade is just that, I am currently on the fence on this but if your gonna make one do it properly and get the £3 plug.
  5. Londondecca
    Londondecca
    Dec 21, 2003
    2,081
    +96
    I am suspicious about the worth of a mains plug but for £3 it is simply not a big deal. I would recommend cleaning all the connectors though.
  6. Hefner
    Hefner
    Sep 29, 2004
    52
    Leeds
    I'm pretty sure it's easier to get wider cable into a toughplug.
    Makes it easier when making up a decent cable.
  7. Timmy C
    Timmy C
    Oct 10, 2003
    5,110
    +382
    Now that makes sense. I can understand paying the extra if it makes putting the cable together easier or if it makes a better connection possible. I just didn't see the point if they were as good as plugs less than half the price!
  8. inzaman
    inzaman
    Dec 16, 2002
    7,959
    Derby
    +1,023
    I'd agree with Hefner, when i made my twisted snakes the tough plug had just enough room to insert the numerous cables into the relevant slots, a cheaper plug just wouldnt have had the space.
    They really are quite easy to work with as well due to this fact, HTH.
  9. Timmy C
    Timmy C
    Oct 10, 2003
    5,110
    +382
    Toughplugs it is then! I'm off to B&Q!
  10. jrrs1
    jrrs1
    Oct 27, 2004
    25
    One reccomendation i was always told about was to clean the brass pins on the plug with 'brasso' until they shine like mad, brass is easy to oxidise in the atmosphere (assuming there brass that is) :D
    I guess the next argument is ... brass vs steel vs etv etc :confused:
    i open the debate 'metals and their conductability'.... ( just joking) :clap:
    Chere John
  11. mo
    mo
    Jul 16, 2000
    769
    london,england
    +23
    on your tv ,chop off the cheap plastic mouldy plug and replace it with a mk one.
    go on, tell me that you cant see a differance.
    and that my friend will answer your question!
  12. simonali
    simonali
    Jul 5, 2004
    61
    Go on, invalidate your warranty! :nono:
    MK tough plugs have binding posts for the electrical connections. This is why they are regarded as being better than standard and nothing to do with pin material etc.
  13. Peridot
    Peridot
    Aug 24, 2004
    2,977
    Newport, South Wales
    +293
    Toughplughs haven't got binding posts, MK safety plugs have (not that it matters) :lesson:
    Changing the plug on your telly won't invalidate the warranty ...
    Nor will it make any difference to the picture or sound quality
    Spend a bit more time enjoying whatever AV kit you have and less time worrying about its mains connection :boring:
    ______________________________________
    Dermot
