MK SW-150s with SW-95 rears
Discussion in 'Home Cinema Speakers' started by sidicks, Sep 15, 2005.
  1. sidicks
    sidicks
    Mar 24, 2004
    12,712
    +1,301
    Looks like my new home cinema set up will be using 3 * MK SW-150 (In wall speakers) for the front left, centre and right channels with SW-95s for the rears.
    Before I make an expensive mistake, is that a good choice ?
    Sidicks
  2. recruit
    recruit
    In simple terms an Excellent choice for speakers especially when you are looking at a discreet solution and the speakers will be flush into the walls, ref to performance for Home Cinema they are pretty much some of the best speakers availible for AV use and not too shabby with music either... :thumbsup:
  3. MadMaelstrom
    MadMaelstrom
    Feb 10, 2005
    1,819
    +164
    I use the SW85's as rear centres and they are excellent, initially i was a little concerned using wall speakers but after i heard them i cant recommend them enough.
    Would love to hear the difference from the cab based 150's to the in wall versions also as my installer said i shouldn't go in-wall all the way.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,714
    The Borders
    +3,077
    Hello sidicks
    Just ensure your amplification is on par with your choice of loudspeakers.
    You don't say what size room, what seating position and what you had in mind subwoofer wise to underpin the M&K Satellites.
    Will you have a chance to play around with the loudspeakers in your room before you finalise positioning?
    Best regards
    Joe
  5. monkeyboy69
    monkeyboy69
    Mar 30, 2002
    589
    +11
    i've also been looking at these for the WAF, by building a 4 inch fake wall and slotting these into it. CAn they bolted directly onto a wall and built around in this fashion.
    Also my best quote is 875 each with free delivery. Can anyone point me in the direction of a cheaper one . cheers
