MK SS150 Speaker Stands
Discussion in 'Home Cinema Speakers' started by guyan123, Nov 26, 2010.
  1. guyan123
    guyan123
    Aug 9, 2010
    296
    +6
    My MK SS150 will be arriving in the next week:D and now i need stands for them.
    The speakers are the old MK SS150.
    Can anyone point me in the right direction.
    Many Thanks
  2. ufitsy
    ufitsy
    Aug 18, 2004
    3,280
    103
    Midlands
    +353
    Do these not have a small wall mounting bracket - a two part thing that you attach to the speaker and drop into the other part that is attached to the wall. It is fairly small about 3cms.
  3. guyan123
    guyan123
    Aug 9, 2010
    296
    +6
    I do not know as i do not have the speakers yet.
    I cannot mount these speakers on a wall so i am looking for stands.
  4. ufitsy
    ufitsy
    Aug 18, 2004
    3,280
    103
    Midlands
    +353
    IIRC the CS are more what you need as the SS150's are supposed to be wall mounted, on the plus side the SS150's are quite sought after so you could move them on easily - are thy MK1 or MK11?
  5. guyan123
    guyan123
    Aug 9, 2010
    296
    +6
    The speakers are the MKI version.
    Instead of using speaker stands I have been thinking about making two shelving units which I will fixed to my wooden beams as i live in a converted barn.
    The beams are about 91 inches from the floor,how high would the speakers need to be?
  6. ufitsy
    ufitsy
    Aug 18, 2004
    3,280
    103
    Midlands
    +353
  7. guyan123
    guyan123
    Aug 9, 2010
    296
    +6
    Does anyone know where i can buy the wall speaker brackets from.
    I decided to put these speakers on the wall after speaking to the landlord.
    I am looking for somethink like the omnimount 53-rst bracket which i cannot find in the UK.
  8. andicapped
    andicapped
    Jun 7, 2006
    1,668
    manchester
    +74
    you'd be better off asking an MK dealer, try [URL removed]
    i've spoken to them a lot about MK stuff, very very helpful
  9. ufitsy
    ufitsy
    Aug 18, 2004
    3,280
    103
    Midlands
    +353
    Put a wanted ad on the speaker classifieds here - someone may have some knocking around.
