Question MK speakers tripole placement
Discussion in 'Home Cinema Speakers' started by mac_monkey, Apr 23, 2018.
  1. mac_monkey
    mac_monkey
    Feb 26, 2005
    621
    28
    Nantwich
    +31
    Hi, while I’ve started a home cinema build thread, in retrospect, one of the questions may be better here.
    In a 5.1 config, Is it ok to put tripoles on the back wall behind the main listening position?
    I’m considering an MK MP950 LCR + SUR95T (or M4T) for rears.
    One of the key considerations to this project is discrete speaker design and placement. At the moment, that means on-walls and the attached layout is preferred. In-walls, while still on the table as a possibility, may prove problematic as it’s a period property with brick/stone walls.
    Thanks in advance.
    Tom
  2. Saul Goodman
    Saul Goodman
    Jul 24, 2012
    1,358
    116
    +1,011
    Yes, that will be absolutely fine.
  3. mac_monkey
    mac_monkey
    Feb 26, 2005
    621
    28
    Nantwich
    +31
    Thanks for the quick reply, I was a little confused about the (claymore-esque) “this side towards screen” directions on the back of the speakers.
    I assume as long as they’re in phase it’s all good? Ie. the arrows point at the listening position.
