Hi all,
I've just purchased an MJ Acoustics Sub Ref 100, and with it i purchased a High Level Lead (10 meter Nuetrik to Solder ends cable). I purchased this over the phone directly from MJ Acoustics without hearing it (they don't usually sell direct, but they did with me because my local dealer was pi**ing me around!!). Now, although i can plug the main end of the cable into the sub, i don't know wher i should be connecting the three wire ends into (yellow, red and black) in a short set of instructions, it says to connect them to my speakers outputs on the amp, but should these not go to a dedicated sub-out part of the amp? My friend also seemed to thinmk that i'd be best to buy a coaxial cable to connect from the amp to the sub as well as this connection, because one connection would be good for music and one would be better for film is this correct?
Please help!
AstroBhoy
P.S. It's a Pioneer AX3 amp i have if anyone needs to see a small gif diagram off the back of the amplifier i can send this (just don't know how to attatch on this thread!?)
Please help!
AstroBhoy
